跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
第五代iPad,2017年3月发布。可在Wi-Fi和LTE中使用32和128 GB存储。具有9.7“视网膜显示器和64位A9处理器”。
20 个问题 查看全部
A1822, Blank Screen After Digitizer Repair
I replaced the digitizer on my  iPad 5th Generation , A1822. When I went to test before closing it up I noticed the screen was blank and would not display anything. I could see it was slightly dark blue so not completely black but it has backlight. After multiple soft resets and multiple hard reset nothing worked. I plugged it in and removed the power supply with no difference. I did this while attempting the various two types of resets.
I reinstalled the old hardware and was shocked when the screen turned on. I proceeded to uninstall the broken hardware and reinstalled the new digitizer. The same thing occurred nothing on the screen with the screen displaying the dark green. I assume this is the back light being turned on. Each time I made sure the battery was not connected to not cause any high amp damage.
A bit confused about what to do next.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
With the new screen connected try pressing the home and power buttons together for 30 to 40 seconds. If apple logo appears then let go.
这个答案有帮助吗?
得分 0
8条评论:
I held both button for at east 20 second. Do you really think the 30 or 40 seconds makes a difference? I will do. Just asking for explanation.
完成的
Yes, some iPads need a hard reset after fitting new parts.
完成的
Thanks for responding. I just did this three times at 60 seconds each and I got nothing to display on screen. I know the new home button that came with the digitizer works because the back light responds, as in turns on back light when I push it. Thanks for the suggestion.
完成的
Leave the digitisers off and only connect the lcd and then turn it on. Just to rule out an lcd issue. I take it the battery screw was in when you were testing the last time?
完成的
@strongbow , I did remove the digitizer to rule things out. From reading and researching this looks like I failed at isolating the battery and damaged the image filter chip.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
lindylex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 169
