跳转到主内容
Game Boy(Game Boy 掌上游戏机)于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
Can I repair problem with power?
Will not turn on with fresh batteries - connections are tight and clean. Power is erratic when adapter is plugged in - the power light comes on and the game plays until just a little jiggle interrupts play then screen goes dark and power light goes out. If I unscrew the back what should I look for?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
katy, check for loose or corroded contacts on your logic board power connector. Try a good cleaning by following this guide Electronics Water Damage. let us know what you find once you open it up, take lots of pictures....:-)
这个答案有帮助吗?
得分 2
添加一条评论
Take a look at these guides. They will assist you in getting into the device.
2 of the battery terminals are soldered directly to the main board so check they are OK and not cracked/loose. Also check the socket where the power adapter plugs in (if it is an option) on the main board - again check the solder joints aren't cracked/loose
HIH
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
katy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,237
