跳转到主内容
The Maxima was redesigned for the 2009 model year and made its debut at the 2008 New York International Auto Show.
OBD giving 1778 engine light code
My car is accelerating slow after coming to stops. The engine light is giving me a 1778 code and after some research I learned that I needed to replace the stepper motor. After replacing the stepper my issues were still there. I tried replacing the Mass air flow sensor and the problem is still there as well. What else could I try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Try searching for Nissan Maxima forums. Owners share info freely and may help you. If you have a cvt, this may be a known problem.
完成的
添加一条评论
1个答案
After installing the parts you have to reset the error codes. You can wait for few miles to detect the issue has been solved and the error code will gone. It is also possible you have some more parts has fault. Please contact any expert technician locally to examine the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Quincy Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 118
