跳转到主内容
加入维修社区 - 创建账户
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
Why won't my phone turn on?
I don't know what happened it was working a few minutes ago until suddenly it started going a little glitch then I tried to turn it off and it worked so I wanted to turn it on again but it isn't working im charging it right now and I don't know what to do I need this fixed in 3 days.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Y.I.N.E try a power cycle first "There are multiple ways to reset your device if you are experiencing issues. The first step is to power cycle your device. Press and hold the Power/Lock button, then select Power off. Select Power off to confirm. To turn the device back on, press and hold the Power/Lock button until the screen lights up.
Note: If you are unable to power your device off or if it becomes unresponsive, press and hold the Power/Lock button for 10 seconds, until it reboots." If that does not work check through other solutions for a software issue on here If none of those work, you have to dig a lot deeper into the bowels of your phone ;-) Follow this flow sheet to narrow it down. the images are best viewed when downloaded and using your own image viewer.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your help but I realized that my phone is just dead since it is a old model and the battery has been steadily declining.
由完成的
@Y.I.N .E just replace the battery and start from there. "just dead" should be an easy fix ;-)
由完成的
添加一条评论
添加你的答案
Y.I.N .E 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 23
总计 908
