跳转到主内容
道奇汽车的修理和支持指南。
2003 dodge sprinter... what is this part?
Sorry but there's no dodge sprinter choice. But what is this part???
On a side note trying to get good info for priming the fuel filter in this van. It has the Mercedes diesel engine.
Update (08/18/2022)
And would this part cause issues running? This van runs fine until noon or so. Then it likes to die...
Update 9/10/2022
Ok that is the EGR but that isn't the issue. Turns out the high pressure fuel pump was the issue. Now I've got a new problem. Someone else pulled the old high pressure fuel pump, and when they did apparently they lost the bracket or whatever it is called that held the fuel lines in. The high pressure one is metal and threads on, looks like might be a double flare on it. But on the other side, 2 plastic fuel lines push into two holes. Then a piece gets bolted onto it. But I can't find a part number or even what it is called. I'm trying to fab one to get it by til a new one can be ordered but I can't order a new one without at least knowing the name.
The arrow is pointing where the lines push into it. There's a plastic plug still in one hole in the pic, and the other hole is empty. I don't like working in this stupid thing but I'm trying to help get a coworker mobile again. Any help would be great.
It is the part numbered 11 in the pic
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @brandon_k
Not quite sure but it looks like an EGR valve of some sort as its location is on the charge air input to the manifold
This link may also be of some help.
Haven't looked at it as it is a 40MB download, but here's a link to the 2003 Sprinter service manuals I think. They are UK based but maybe they're the same vehicle except they're RHD (scroll down to find the 2003 SprinterManuals.zip file) ;-)
Cheers
这个答案有帮助吗?
得分 1
4条评论:
Hi @brandon_k ,
Did you try looking in the service manual I mentioned above?
完成的
I did. It even shows it in there. However it only labels it as a bracket. And I can't find anything for it so that I can get a part number or anything. I'll put another screenshot up of the manual.
完成的
@brandon_k
Bit difficult to link as my phone is old but searching online for "2003 Dodge Sprinter high pressure injection pump bracket" brought up sites that sells parts but mainly the complete pump. Might be worth checking out
完成的
@jayeff alright I'll check it out. Though the new pump we got didn't come with that bracket.
完成的
添加一条评论
添加你的答案
brandon k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 71
