跳转到主内容
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 个问题 查看全部
Truck will not start, died in parking lot wile pulling into a spot
My son (16) got himself this hobby truck. (1997 ranger) He was learning to drive in a parking lot (it’s manual). He killed it pulling into a parking spot, and now it will not start. It is getting power from the battery to the cab/dash display. However the engine makes no sounds, does not click, doesn’t try to turn over, nothing. What should he look at? This mom knows nothing about fixing vehicles.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Everyone starting out learning how to drive a manual usually kills the engine with no harm. No starter sounds suggests; dead battery, loose/corroded battery cables and their connections, worn out starter.
这个答案有帮助吗?
得分 0
添加一条评论
@mikesride "the engine makes no sounds, does not click, doesn’t try to turn over, nothing" make sure that you check the clutch safety switch, besides all of those great things previously mentioned. A failed switch would have all of those symptoms as well. Should be pretty close to something like this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 72
