跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Diagnose why laptop won’t charge
I am not getting a green light on my MacSafe adapter and my computer will not power up. It thinks it is plugged in because when I hit the power button it displays the empty battery symbol with a lightening bolt, but no plug
I replaced my power supply and batteries a couple of years ago so I am suspicious the problem is somewhere else. Is there a way to determine whether the problem is in the MagSafe board or the logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
It could be a internal issue. Most probably liquid or moisture damage on the logic board. as it is quite old model, this is very common in macbooks. its better to get it diagnosed by a technician. i have repaired hundred of macbooks with this problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sara Shoemaker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 66
