跳转到主内容
Steam Deck 是 Vavle 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
20 个问题 查看全部
Dropped Steam Deck - Broke Left Daughterboard
I dropped my steam deck and the LB quit working. It appears I broke the little blue piece that the LB makes contact with to produce the clicking noise. So I believe I need a new Left Daughterboard, which iFixit does not sell. I have attached pictures, sorry for the quality. Valve has still not gotten back to me after a couple of days. Can anyone verify that I need a new daughterboard? Does anyone know how I can get one? Or does anyone have any experience/advice with this? Any help is welcome. Thanks for your time. I'm beginning to worry there isn't a fix....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
4个答案
最有帮助的答案
it just needs the button replaced, you would need to get someone to be able to source a suitable replacement and be able to solder it on to the board
这个答案有帮助吗?
得分 4
5条评论:
you are wrong
完成的
@spocksbrain how exactly, does the posted photos not show a broken button ( yes ) is a button replaceable ( yes ).
完成的
@tech_ni Love how there is no explanation, just "you are wrong". LOL!
完成的
@betatechlabs yea 2 years and still no answer to why im wrong even tho iv done plenty of repairs like this and more difficult repairs.
完成的
@tech_ni "You are wrong"
Lol!
完成的
添加一条评论
the daughterboards still are not in stock and i suspect they sell out instantly whenever they are in stock. that fragile flimsy microswitch is the number 1 most broken piece on this hardware.
这个答案有帮助吗?
得分 2
3条评论:
Hi, there are compatible switches e.g. on aliexpress. look for "Steam deck button/switch" or "XBOX 360 pair switch". A smartphone repair shop can swap the switch for little money
完成的
@dawid68075 you will probably be wrong aswell as i was for saying the same thing
完成的
@tech_ni I overlooked your answer :D we both are wrong, lol
完成的
添加一条评论
iFixit does have the part listed, but it's currently not on sale:
[关联产品丢失或禁用: IF260-022]
Currently I have this problem too (although the switch did not come off of the daughter board)
这个答案有帮助吗?
得分 0
2条评论:
I ultimately decided to RMA the deck.
完成的
what does RMA mean?
完成的
添加一条评论
Hi,⏎
The transistor on the left daughterboard is missing. I would like to buy a new transistor and solder it myself. Could you please provide me with the specifications of the transistor or give me a link to purchase one? The L2 button is not working because of it.⏎
See the blue arrows in the attachment: https://imgur.com/a/lfLIQbR
这个答案有帮助吗?
得分 0
1条评论:
Hi, this is most likely a linear hall sensor or some other kind of magnetive resistor. I do not know the part name/identifier, unfortunately
完成的
添加一条评论
添加你的答案
Taylor Spivey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 2,840
