跳转到主内容
beko fridge freezer too cold
Hi
Beko fridge freezer frost free is too cold that it is making lots ice in the fridge area where it should not make ice. I have defrosted fridge and when it is back on, it starts making ice again. thermostat at minimum. please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
It sounds like your fridge might need a new tstat, or the damper between fridge and freezer is stuck open, instead of regulating the amount of cold air that enters the fridge section. I'm not familiar with the layout of this particular fridge, as you need to post model number of the unit, but try finding where the cold air enters from the freezer section, and removing panels to access the damper. Try moving the damper yourself by hand. Carefully. Don't bend or break anything doing it.
完成的
添加一条评论
1个答案
I'm so sorry to hear about your issue here. I also faced the same issues. But later on, I noticed that the temperature was so high. And I fixed the issues.
这个答案有帮助吗?
得分 -1
1条评论:
This doesn't help.. what issues did you fix? How did you fix them?
完成的
添加一条评论
添加你的答案
Efe 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 6
总计 527
