跳转到主内容
加入维修社区 - 创建账户
GE 微波炉型号 JVM1650BB 007 是一款 1.6 立方英尺容量、1000 瓦功率,并带有外部通风系统的微波炉。
New line fuse needed?
My microwave use ceramic line fuse 20A 250V
Can I use any ceramic fuse if rating is the same even if it is not a line fuse or do I need to use a line fuse?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi
Do you know for sure it’s the fuse?
To confirm it I would get a multi metre in continuity mode and check for a beep:-)
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @k1love
As long as the rating is the same i.e. same volts and amps, that it is a ceramic fuse and that it fits securely into the fuse holder, it will be OK .
If you want the manufacturer's recommended replacement fuse, search online for WB27X10928 to find suppliers of the fuse that suits you best.
There is always a reason why a fuse has blown so perhaps get 2 or 3 just in case you haven't found the reason why the fuse blew as it may happen again soon after you replace it.
Be safety aware when working in a microwave oven. The HV capacitor in the oven can store >6000V DC for months even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the microwave's cover has been removed and before commencing any further work inside the oven.
Protects the microwave from electrical damage by breaking the circuit during power surges or faults.图片
产品
GE Microwave Fuse - WB27X10928
$18.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
KLove 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 417
