跳转到主内容
加入维修社区 - 创建账户
M3D Micro 是一款经济实惠且结构紧凑的 3D 打印机。
Help recognizing burned component
Hi M3D Micro owners!
I have recently noticed one component (I think is a transistor) is burned, and I need help knowing which one it is.
I didn't find any schematics for the board, so I have no clue.
I would really appreciate any help here. I want to replace the component and fix the printer.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Which board is this? Is this the logic board or the Power and Data board?
由完成的 分享
I think my Micro is the first one they released, since I bought it from Kickstarter. Therefore it only has one logic board.
I have edited my comment, adding the full board image.
Thanks Jacob!
由完成的 分享
Это стабилизатор питания на 3,3V для микроконтроллера. Если его пробило, через него мог сгореть и контроллер.
This is a 3.3 V power stabilizer for the microcontroller. If it broke through, the controller could also burn through it.
由完成的 分享
SOT-23 XC6206P332 or XC6206 or SMD(662K) 3,3 В/0.5A
由完成的 分享
添加一条评论
2个答案
已选择的解决方案
check out this datasheet
https://www.diodes.com/assets/Datasheets...
GW9 = AP2127N-3.3TRG1 = 3.3V regulator
这个答案有帮助吗?
得分 4
3条评论:
@ruggb same result for me. Got the right symbol and right marking.
由完成的 分享
Thank you! I think you have found it! I will order the component, replace it and let you know.
由完成的 分享
I found a cheap option to order it from Europe, if someone else is interested:
https://a.aliexpress.com/_uv6bsR
由完成的 分享
添加一条评论
Hi @kuruchy
For what it is worth here's a zoomed in image from Step.7 of the ifixit M3D Micro 数据和电源接口更换 which shows the component.
Although what GW9 (I think) means I don't know. Looking at this link it may be some sort of voltage regulator?, but as to its value that is also something else, I don't know.
Then again it may just be the component manufacturer's marking and not a value marking
(click on image to enlarge)
Hopefully a start
这个答案有帮助吗?
得分 3
4条评论:
hi @jayeff, thanks 👍.
Taking a look at the circuit itself, and how it got burned, it makes total sense that it is a voltage regulator.
With GW9 at least I have a hint on how and what to test.
由完成的 分享
If anyone has more info to which component exactly is, would be great.
由完成的 分享
Taking a look at all the manuals you added, it could also be a voltage detector.
由完成的 分享
@kuruchy
True.
Long shot perhaps but looking at the image you provided are there any other similar sized ICs on the board having the same marking as the faulty one?
Sometimes more than one may be used in a circuit.
If there is it may give some idea as to what it might do, depending on where it is situated.
Very hard to know without a schematic. ;-(
由完成的 分享
添加一条评论
添加你的答案
Bruno Retolaza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 44
总计 794
