跳转到主内容
加入维修社区 - 创建账户
2004 年发布的 HP Compaq 商务笔记本电脑。该机型与之前发布的 Compaq 机型有许多相似之处。所有该型号笔记本电脑均使用 Pentium M 处理器(仅支持 32 位),但运行速度根据您的具体配置有所不同。
System looses power after 10 seconds
I've had this thing forever and out of nowhere it would turn off after turning on for 10 seconds. It was booting into windows XP perfectly fine and then the issue would return. Online is no help just saying to apply pressure on a part near the power button for the duration you want to use it, I'm looking for a long lasting solution. Others have the same issue so it seems to be a design flaw. It may help that the pcb for the power buttons is separate from the main mobo.
The power button pcb on it's own
Main mobo without the button pcb
The pcb connected
Update (06/02/2022)
@uchetil I can solder, the thing is I'm not sure what exact chip I need to re-solder. I remember this video shows where to apply pressure when powering on. Also I remember once getting it to stay on longer than 10 seconds only turning off when I manually shut it off so I could figure out which one I held down. https://www.youtube.com/watch?v=ILLvioWt...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
How are your soldiering skills? If that temporary fix you saw works for you then it looks like the problem is the solder joint's on a chip, are you equipped and comfortable with trying it yourself? (Re soldering a chip). I'm intrigued by your problem and still looking into it. Have you by any chance tried reseating the video connector? One post I saw mentioned this cured similar symptoms. I'll post an answer after I finish researching this. If someone else doesn't give you a solution first. You might try the apple solution and put rubber on the chip so the case presses the chip down but I'm with you, Id rather fix the actual problem.
完成的
Sandi Lorenz here is the schematic for your computer.HP Compaq NC6000 Check page 8 which shows the power on circuitry and it appears as if U4000 could be the offending IC
完成的
Thanks, mike!
完成的
@uchetil anytime Sir. Glad to be of assistance.
完成的
添加一条评论
1个答案
最有帮助的答案
I can tell you which chip is "reputedly" the culprit, it was mentioned in several places. I just checked four sites agree it is the MAXIM 1987. And yes it can be done with a magnifying glass Steady hands and possibly a bit of practice if needed. Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sandi Lorenz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 595
