Why is the bottom thrid half of my screen flickering white
the thrid bottom half of my phone flickers white and sometimes green and everytime I turn off my phone it won't turn back on unless I press the power button multiple times.
@katelynnkatelyn sounds like you are having a broken screen. For now, disassemble the phone, check the display connector to make sure it is properly seated and shows no bend pins, corrosion etc. If that works out okay you will have top replace the display and re-evaluate.
这个答案有帮助吗?
The bottom of my phone s10 is flickering constantly like 2/10 of my screen how do I fix the problem??I dropped it but its not cracked
@daevdshula teh glass may not have cracked but sounds like the matrix took a hit. Without seeing it and strictly going by your descriptions, a new display should fix this.
Go to developer mode through settings
Disable HW overlay
And that's it.
Basically it's firmware issue but sometimes this type of error/Flickering is caused by non suitable settings.
Try this bro
这个答案有帮助吗?
If u have the eye comfort shield setting on turn it off. This is what fixed it when I had the same problem
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 180
总计 4,707
