跳转到主内容
Repair guides and troubleshooting for the HP Chromebook, an 14 inch HP-brand laptop computer that runs on the Chrome operating system (OS).
Bluetooth not working even after sending it to HP
I had no issue with Bluetooth of my HP Chromebook Model 14c- ca0235ng for sometime. The mobile phones got connected, one phone was paired.
All of sudden, the mobile phones were not recognized. (Strangely the Bravia TV gets recognized by Bluetooth).
I contacted HP and talked with them. Since it was under guarantee, HP asked to send it to them for repair. Few weeks later, I received my laptop back.
In a paper from HP, it was mentioned that motherboard was changed.
I started my Chromebook, switched Bluetooth and searched for devices and lo, the issue was still there! Grrrr...
So my question: Does anyone know what the problem could be? Except the Bravia TV, the chromebook simply does not display any of my devices. If i check from mobile phone, the Chromebook is also not to be seen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Is bluetooth switched on in the settings? Also check that your Bluetooth network isn't hidden (so other devices can see and connect)
If there are devices saved that connected previously I would remove them, restart the device, then try to connect them again.
这个答案有帮助吗?
得分 1
4条评论:
I forgot to mention to go to settings and check for any updates that might have been released, it could be a bug from a previous update that is now fixed.
完成的
Yes, Bluetooth is on. Strangely, I can pair it with TV, headsets, etc. But only mobiles are not visible. Do you know if Chrome OS has any codes that identifies and distinguishes mobile phones with other devices? I remember that I had a beta version for some time before this issue started.
完成的
Have you checked in settings for updates? I can't see why you couldn't connect a phone to your Bluetooth. What might be the case is that the bluetooth will only connect to outputs, like speakers etc. That's just a guess though.
Check for updates in settings on your phone also.
All devices have MAC addresses, this identifies the type of device and your Bluetooth module assigns them accordingly.
完成的
Week, Chrome OS is running with latest update, Bluetooth IS connecting. I've tried with 4 different mobiles! 😥 Chromebook isn't visible on mobiles, mobiles aren't visible on Chromebook. With eachother, they can connect i.e. Bluetooth is in visible mode when scanning.
Question is how does Chrome OS work with Bluetooth? An external Bluetooth adapter in USB doesn't work like it does on a windows machine. (I've tried it).
完成的
添加一条评论
I think you have two options: Send it back to HP again, and tell them it's still not working, or buy a new one.
Edit: I think I may have figured out the issue. If you have an Android phone, then Chrome OS pairs to it using a new feature, "Pair with Android phone", under Connected Devices, not Bluetooth.
My Chromebook is managed by an organization, so I can't confirm if this works, but I definitely can show you where the setting is.
这个答案有帮助吗?
得分 1
4条评论:
Perhaps it is a 'feature' not a flaw. In researching your problem I found this on Google's Chromebook support page:
"Tip: Your phone cannot pair to your Chromebook with Bluetooth.'
On a different page however it mentions chrome OS 71 and up. Check in your settings app, if your version is not at least 71, update and try again. I doubt this is the problem since it looks like updates are supposed to be automatic, still worth checking. How to update (if you need). Is Here
完成的
Thanks!
The Chrome OS is updated to latest stable release (101).
完成的
@whispher Hey, read the edit, I think I may have solved the issue.
完成的
My mobile was paired. But now it is not possible because Chromebook does not find it. :(
完成的
添加一条评论
Well check your Bluetooth setting and also check for Bluetooth driver update as well
这个答案有帮助吗?
得分 0
2条评论:
Bluetooth settings are perfectly okay. I can pair it with TV, headsets, etc. But only mobiles are not visible.
完成的
By the way, there's no such thing as "update to the latest driver" on Chrome OS like on Windows.
完成的
添加一条评论
添加你的答案
Ketan Jansari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 295
