跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
430 个问题 查看全部
Xbox power supply flickering green and orange.
Hi, my Xbox 360 isn't powering on and the power supply is flickering between green and orange. The console itself has the center green light lit on the power button and is clicking (No HDD installed and I presume its the fan attempting to spin up?) anyone have any clue what the issue could be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@macintoshing the PSU has built-in safeguards to help prevent damage to either the console or to the power supply itself. It will turn off in cases of over current, over voltage and over heating. Whenever some situation like that occurs the light will turn from green to orange or to red. I suggest that you take a look at the possibility of it overheating. Use this guide Xbox 360 Power Supply Teardown to work on it. Or if you are stuck with anything while working on it, you can always post images with your QUESTION. 在已经存在的问题里加入图片
Xbox 360图片
指南
难度:
中等
15 - 30 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 1
添加一条评论
I second @oldturkey03. I have experienced this myself and found that due to excessive buildup of dirt and other particulates in the intake and exhaust of the power supply, the unit would regularly overheat mid gameplay. Upon clearing the vents, I was able to gain extended periods without the overheating however, I believe the power supply was ultimately damaged from many overheating events prior to my realization that cleaning was needed as it eventually died, and I had to purchase a new one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Macintoshing 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 43
总计 734
