跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
Restore battery data without original battery
Hello I wanted to ask can you restore battery health without original battery? The message I know we can't take it out cause I don't have the original
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Taking the gas tank out of your car only to put it back because its empty won't work either ;-{
Batteries over time break down or wear out, taking them out and the putting it ban won't change anything.
If you have a Mac you could plug it into it and then using a program like CoconutBattery getting the full version will allow you to check your battery a bit better than what Apple or many on phone apps offer and if the phone won't turn on it might also work.
这个答案有帮助吗?
得分 0
2条评论:
No I mean that I have a phone se without original.battery , and doesn't show battery health and saying battery is not genue, so can I restore battery health without original.battery? Like true tone without original display with qianli device
完成的
@ibitaz - Bad battery then! Some batts are not compliant to what Apple needs for data input from the battery.
There is a small micro-controller chip within the battery which has programing to tell the phone what's happening within the battery. Either it's not programed correctly or the connection to the logic board is bad or missing (cable).
完成的
添加一条评论
添加你的答案
Stelios K. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 476
