跳转到主内容
加入维修社区 - 创建账户
2021 年 10 月发布的 16 英寸 MacBook Pro 的维修指南和拆解信息,配备 Apple 设计的 M1 Pro 和 M1 Max SoC。型号 A2485。
cracked screen turned black
Hi, I accidentally closed the MBP 2021 M1 Max 16 inch and there was a little USB .
Screen cracked, in the begginning there were some vertical and horizontal lines but now it completely turned BLACK. Is there any solution(replace the display)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My MBP 16 inch 2021 m1 max 64gb 1TB. I will bring it to one of the apple related store. I have no apple care.
I will let you know the result. I paid nearly 3700usd and i have this usb crash after 2 months of use... Poooooof.
Thanks guys for all the advices.
由完成的
添加一条评论
4个答案
已选择的解决方案
Hey Psyke,
I'm sorry to hear about this. Unfortunately because of how new this product is your only option is to take it to apple as parts for these are non-existent outside of Apple and/or AASP (Apple Authorised Service Providers).
这个答案有帮助吗?
得分 6
添加一条评论
The warranty period is one year, and the device was released less than one year ago, you can take it to the Apple Store and see what they will do
这个答案有帮助吗?
得分 2
6条评论:
Well its not so simple ;-{
Apple will only repair or replace systems under warranty which have a product defect not one caused by the owner. A cracked display falls in that space it won't be covered.
IF the OP had bought a service contract (AppleCare+) then the cost of the repair labor will be covered and part of the parts cost (I think its half here) So the OP is on the hook for ~ $400 USD (for reference a 2019 display is $820 new) and then you need to add the labor.
由完成的
@danj It's a shame it broke in 6 months, as that is at least a $3000+ machine.
由完成的
@guardian10 - lowest end prebuilt is $2,500 the top prebuilt is $3,500 and it goes upto $6000 with more RAM and storage. Just a little bit of pocket change ;-}
由完成的
@danj He said his had an M1 Max and was a 16". The lowest end of those is $3299.
由完成的
@guardian10 - True! But what was the config? As we don't know I just gave the vanilla answer addressing the range.
由完成的
显示更多的1条评论
添加一条评论
what did u do finally? mine is broken too :(
这个答案有帮助吗?
得分 0
添加一条评论
Mine is broken I send it to apple , cost 950€ , but they find some corrosion (water ?) and want to change the logic board 1700€ , but the Mac was working with a second screen .
They don't want to repare without changing the logic board, I can change the screen myself but it's impossible to find screen I f somebody have a solution
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Psyke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 3,495
