跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
Display change with an original
Hello, i have been searching but I can't find anywhere, so my question is, if we replace an iphone 11 pro max display with another original one and we reprogram it for true tone,we still get display message even if the screen we reprogram is original? The only way is to transplant t the chip for that message to go away?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
That is correct.
完成的
Thanks for the answer, so only way for the message original display or not chip needs to be transplant I got it correct?
完成的
添加一条评论
2个答案
最有帮助的答案
It doesn’t matter if it is an aftermarket, refurbished or another original 11 pro max screen. You will need to transfer the chip from the screen that was originally on the phone.
这个答案有帮助吗?
得分 2
添加一条评论
Correct. Chip needs swapping over unfortunately.
Or if you know a refurber, they can either change just the top layer of glass of the damaged one, or change the touch panel/glass without the IC on the flex, and then reflow the original one on the new touch panel flex.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stelios K. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 284
