跳转到主内容
The Minolta X-700 is a film camera introduced by Minolta. we offer information on how to replace battery, shutter, light seal, capacitor.
4 个问题 查看全部
Why won’t my camera turn on
Shows no life as I put battery into it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
@michellea first make sure that you have the right batteries. You need two 1.5 to 1.55 volt batteries. Make sure that you have the batteries properly inserted and that the battery connections are not corroded etc. . After that turn the cameras power switch on.
If that does not get you any results you will have to dig deeper. the error could be on the flex cable or the PCB. For that repair you do want to go ahead and use the Minolta X700 Service Manual
这个答案有帮助吗?
得分 1
1条评论:
@oldturkey03 - Love the mask!
完成的
添加一条评论
You'll need to check the battery compartment to see if the contacts are corroded.
这个答案有帮助吗?
得分 0
添加一条评论
Check corrosion on the battery door/cap even if it doesn’t look corroded clean with vinegar.
Source: worked with mine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michelle 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 79
总计 2,665
