Why won’t my camera turn on
Shows no life as I put battery into it
@michellea first make sure that you have the right batteries. You need two 1.5 to 1.55 volt batteries. Make sure that you have the batteries properly inserted and that the battery connections are not corroded etc. . After that turn the cameras power switch on.
If that does not get you any results you will have to dig deeper. the error could be on the flex cable or the PCB. For that repair you do want to go ahead and use the Minolta X700 Service Manual
这个答案有帮助吗?
@oldturkey03 - Love the mask!
You'll need to check the battery compartment to see if the contacts are corroded.
这个答案有帮助吗?
Check corrosion on the battery door/cap even if it doesn’t look corroded clean with vinegar.
Source: worked with mine
这个答案有帮助吗?
过去的24小时: 3
过去的7天: 21
过去的30天: 92
总计 345
