跳转到主内容
Repair information for flash memory card readers, which are adapters that read flash memory media including SD, MMC, and smart card readers, usually with a USB interface.
1 个问题 查看全部
Metal thing in card reader bent out of shape. How to fix?!
My SanDisk MobileMate SD+ Memory Card Reader won't accept mini SDHCs anymore!
Peering into the slot reveals that one of the thin metal things that presumably come into contact with the SDHC's pins is bent severely out of shape, and prevents the card from going in.
My guess is that I'm either going to have to take it apart to fix it—or try to ply it back into shape using needles or something.
But what do you knowledgeable folks think??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
not sure how deep that is, but I have a set of Hartman Forceps that I use in case I need to bend some pins back. They are a bit expensive (around $10) on ebay but are a valuable tool.
完成的
添加一条评论
1个答案
已选择的解决方案
chiabuns, I would first try to bend the pins back. They do not tolerate a lot of back and forth movement, so be careful. I am also not sure how deep that is, but I have a set of Hartman Forceps that I use in cases where I need to bend some pins back. They are a bit expensive (around $10) on ebay but are a valuable tool. Good Luck.
这个答案有帮助吗?
得分 2
2条评论:
That is definitely something I will try as soon as finals are over! Hopefully the pin isn't too mangled for me to manipulate back into shape. Thanks for the advice!
完成的
Good Luck with your card reader....and your finals :-)
完成的
添加一条评论
添加你的答案
chiabuns 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 4,751
