跳转到主内容
Convertible 2 in 1 Touchscreen Laptop released in 2012 by Lenovo.
3 个问题 查看全部
Why is my fan making noise?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
How old is the computer? Have you cleaned the computer fan?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
The fan may be noisy because it is operating at high speed trying to keep the CPU cool. This could be due to accumulated dust in the fan/fan vent preventing the heat from escaping efficiently or because the CPU is getting too hot. Given the laptop may be nearly 10 years old, has the thermal paste on the CPU been refreshed at all?
It may also be noisy simply because its bearings are wearing out.
Here’s the hardware maintenance manual for the laptop.
Go to p.75 to view the necessary pre-requisite steps and then the procedure to remove the thermal fan assembly. This will allow you to clean the fan/fan vent if dusty, listen to the bearings and also since the heat sink over the CPU has also been removed, inspect the condition of the thermal paste on the CPU. If it has dried out then it needs to be carefully cleaned off and replenished with a new coating of thermal paste.
If the fan is faulty and needs to be replaced. Search online for 04W6940 to get results for suppliers that suit you best.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matthew Rossini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 5,477
