跳转到主内容
Repair documentation and service information for Hisense televisions.
HISENSE tv sound but no picture 75h6570g
I have a 75 inch hisense tv ( 75h6570g ). I get sound on the tv but no picture unless I hold a light up to it. I’ve taken the tv apart and replaced the power board and the issue is still the same. I can hear sound and only see a picture when I hold a light up to the tv. What should I do next ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @brokentvmatt ,
Seems like you have a backlight problem.
This could be either faulty LED strips or since you have replaced the power board, the mainboard telling the power board not to turn on the backlights for some reason.
Without a schematic (I can’t find one) to know where to check voltage signals between the mainboard and power board and as the audio is working and you can “see” video, to me it points to the problem being either the mainboard or the backlights.
Since you have the TV dis-assembled, consider getting a backlight tester (supplier example only) and connecting it to the disconnected LED power cable, (assuming it is connected to the power board) to test the backlights, independent of the TV being powered on.
If all the backlights turn on, then it’s looking like a mainboard problem
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Matt hildebrand 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 1,069
