跳转到主内容
The BlackBerry 8830 is a smartphone that instead operates on CDMA2000/EV-DO networks and includes GPS.
2 个问题 查看全部
My blackberry 8830 blank out the screen
i have this blackberry 8830, it was working fine, but suddently the screen turn completely white, I turn it off and on back and didn't restore the screen. Now a have a BB that have a white screen that i can not anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
most bb I've had with a white screen need a new LCD
完成的
添加一条评论
4个答案
最有帮助的答案
Not sure if you already tried to remove the battery to reset the BB. You also want to try to reload the OS by using your Blackberry Desktop software. now what I read earlier, while researching another question, was that there is the possibility of a shortening out of some pins. Check on here even so it is for a Curve, it still applies to your phone as well. Hope this helps and gets you started.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, how are you? You must replace your LCD screen, before buying a new piece, look the backside on the broken LCD, there's a serial a number like: 007/111, 001/111. That's your LCD number, you must buy a new one that have that serial number. If you look around the site you'll find some guides that explain how you can replace the screen. I hope this helps you! Sorry about my English. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Agree with gonzalobonini, you'd better pay attention to the LCD serial numerber
这个答案有帮助吗?
得分 1
添加一条评论
Dismantling screen
Dismantling screen
Dismantling screen
Dismantling screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 11
总计 1,439
