跳转到主内容
7.2 megapixels, 3x optical zoom, 2.5 inch LCD screen, released in August 2006
5 个问题 查看全部
Camera Shows "Lens Error"
The camera powers on, and briefly shows an image on the LCD display. Then eventually it gives a "Lens Error" message.
Has anybody gotten this error before? Know how to fix it, I'm thinking that since the camera shows an image on the LCD, it may be a software rather than hardware problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
what error no. does it give?
完成的
pollytintop, I think it's one of those cameras that just says "Lens Error". Usual cause is sand grid and grime in the rings, a dislodged lens, or faulty lens motor. :-)
完成的
Any way to fix it?
完成的
添加一条评论
1个答案
已选择的解决方案
If the lens does not extend/retract properly, then you most likely have something stuck in the zoom gears. If the lens extends but you hear a high pitched buzzing noise, it is the focus motor that is the gears are out or your have debris it it. I would start by reading these tips and see what you get. Also take a quick look at this video to see what you might be up against :-) hope this helps, good luck
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Danny Arenales 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 13,256
