跳转到主内容
Read SSD data with adapter
Hi,
My Macbook Air (1466/EMC2925) has passed away. I disassembled it and took out the SSD. I thought it would be easy to connect it to an adapter. It turns out that the adapter is pretty expensive (119 euro/140 dollar). I think that’s pretty expensive just for an adapter.
Is there a inexpensive adapter(maybe from Aliexpress) which i can buy? I was aiming for around 20 dollars. Basically it is just a converter to USB/SATA 3,5’’
Kind regards!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What country are you located in?
完成的
添加一条评论
1个答案
已选择的解决方案
Apple did their own thing! As such you need to use this custom case External SSD Enclosure for Select Mid 2013 to Mid 2015 Macs or OWC ENVOY PRO
To learn more on Apples custom drives give this a read The Ultimate Guide to Apple’s Proprietary SSDs
I haven’t seen to many other options. There are a few PC cards which allow you to fit the drives into a Windows PC.
Use the SSD originally installed in your Mac as an external drive in this enclosure. USB 3.0 transfer speeds up to 500 MB/s图片
产品
$99.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fixxxm8 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
