跳转到主内容
加入维修社区 - 创建账户
Logitech Surround Sound Speakers Z906(2010 年发布)的维修指南、拆解信息和故障排除。
Logitech z906 no power
Hi, my z906 was playing at low stable volume today and it just randomly cut out power and isn't powering on, there wasn't any smell whatsoever
I'm no expert in repair but feel pretty handy so want to try if i can repair my trusty Logitech Z906 here first before doing anything.
I cracked it open and tried to look for any marks of something blowing and found the following (see pictures)
Can someone point me if its repairable and if I should even bother or just get a new set?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Hi mate, the Component that is burned need to be de soldered and a new one put in its place,
Once the Component has been removed check that you don't have a short to ground.
Otherwise when you power it up after replacing the Component it will just pop again.
If you have the equipment such as a soldering station etc then very easy fix.
这个答案有帮助吗?
得分 1
3条评论:
Hi, do you know where I could get that component from?
由完成的
Hi mate just from looking at the picture alone I am unable to tell you what component goes there and to what value the Component must be.
I am not that sure can you find a schematic for the device online maybe able to tell component from that.
Sorry I can't really help no more
由完成的
@dmmyd see if you can post a large clear picture of the circuit board. Yes, you do have corrosion damage and looks like a couple of coils are toast. Possibly even the IC right besides it. There should be some sort of PCB number on it. Let's see if we can identify this for you via a schematic or a spare board.
Ok so looks like this beast is well known for a bad power supply and schematics are not available. How ever it appears that you will need a power supply that produces 46V 12V and 5V. If you are willing, ready and able you could consider fitting a different power supply. There will be tinkering involved so make sure you want to go that route.
由完成的
添加一条评论
Của bạn bị cháy con điện trở RL1.
这个答案有帮助吗?
得分 0
添加一条评论
Hi' I am from Philippines and same happening to my Logitech z906 after power interruption repeatedly now cannot power On.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Damian Mydlak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 66
总计 4,368
