跳转到主内容
加入维修社区 - 创建账户
50" Plasma TV by Sanyo released in 2007.
Tv turns itself on and off
when i turn the tv on its just a black screen and it will turn itself off and back on constantly
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
The sound on my TV goes up and down
完成的
添加一条评论
3个答案
已选择的解决方案
Tim, i hope you are handy with a soldering iron. I would start looking at the capacitors on your power board. It sounds like you have a few that might need replacing. It is also possible that a mosfet on your board has failed. You can download the service manual from here Check your power board and see if your caps are either leaking (sticky oil like substance on the PCB) or if the tops are bulging. Those are the once to replace. Parts are available at places like this if you want to replace the board. Your caps can be purchased inexpensively at places like Mouser.com and Digikey.com Of course, make sure that you read and follow the safety precaution when and if you decide to work on your TV. Hope this helps, good Luck
这个答案有帮助吗?
得分 4
添加一条评论
I have the same problem and decided to replace the whole power board; filter board and TNPA4774AG SS Board... still not working..
then using my oscilloscope i measured the frequency, and noticed that it was the RF board, N7AE or 1AA4B1ON22900..
All these parts are available from Shop Jimmy.com
I compared prices with a TV repair shop and there was a massive saving if you do it yourself. ( If you know how to unplug a power socket, then you can do this yourself )
TV SERVICE GUY $695 plus labor
Shop Jimmy.com $250, FREE SHIPPING.
这个答案有帮助吗?
得分 1
添加一条评论
Thus this tv got fuse probably going out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 16,470
