跳转到主内容
蘋果2020年的主流型號iPhone,其發布於10月23日,搭載6.1吋OLED螢幕及12MP雙鏡頭模組。其有著5種顏色,為iPhone11的後繼產品。
20 个问题 查看全部
iPhone 12 not charging and turning on
Hello, I was dealing with the issue of not being able to turn on my phone, I tried to start a restart on my phone, hopefully that it would work but didn’t. I thought maybe its dead so i charaged it over night yet the next morning, it doesn’t turn on, when i plug in my phone it won’t show the low battery symbol or show if i have low battery whatsoever. I tried using different charging cables and ports but nothing seems to be working. Should I take it to the store and see if they could help? what should I do? :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
This sounds like the *most likely* culprit is bad screen. The OLED iPhone 12 screens are very sensitive and all or nothing. It doesn’t take much to kill the screen entirely. Your next step is to rule out bad screen with a replacement. If that is too costly, then the next best step would be to use a usb ammeter to confirm that the phone is charging and therefore it is even more likely a bad screen.
这个答案有帮助吗?
得分 1
添加一条评论
An option if you have a wireless charger is to try that, if it works than the lighting port may have a issue.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Alday 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 36
总计 1,720
