跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
Why does my screen flash white and turn off
after i managed to change the bottom screen using your guides i now have another problem where the console wont stay on and all i get is a quick white flash then it shuts down what is wrong?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
shane, it tries to start up and then one of the screens flashes and it then powers down, notifies you that there is a problem with the screen. This is a check and that the screen that is not flashing has an error. Either the screen itself or the cable to it. If both screen flash, it is some other system error, like a loose or broken upper LCD cable. In your case, double check your work, make sure that your cable is seated properly and that the upper cable, which goes through the hinge, is not broken. The guides for your DSi are here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
I had this issue. My bottom LCD would flash white very quickly and then the system would shut down. I ended up needing to re seat what I believe was the LCD cable for the top screen (this the only ribbon cable that is attached to the bottom side of the board) after that it was all good.
Man I thought I bricked it for a minute though and I was worried.
这个答案有帮助吗?
得分 0
2条评论:
I know this is old, but how did you fix it, cause I'm having this issue.
完成的
Had the same issue. Reseating the screen cable worked for me.
完成的
添加一条评论
添加你的答案
shane 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 61
总计 11,449
