memory card error
hi,can u pls help me..always appear on my camera c:13:01 when i'll put a memory into it.. BR usiala
About the C:13:01, the Sony manual says it may be due to the hardware faults or may be your memory stick is not formatted properly. It is possible that the problem is in the camera, that the cable connector of the card reader is not making proper connection. It is also possible that the card reader itself not making proper contact with the card. One of the tings that you can do is to take a pencil eraser and rub it on the gold contacts on the memory stick. Do this until you get all the gold contacts nice and clean. Put the stick in the camera, switch to 'Setup', then turn the camera on. The 'C:13:01' error should automatically disappear. Format the memory stick using the camera's format feature.There are a few more tricks listed right here. Hope this helps, good luck.
这个答案有帮助吗?
but my camera does not format...says system error ........what can i do?!
这个答案有帮助吗?
have you tried a different card? what have you tried so far?
Hi I have a sony 250p super steady shot dvcam digital camcorder super steady shot I have the 64 bit memory stick when I insert it in the slot I get this message format error can any one help please
John.
这个答案有帮助吗?
Please I need an help .my card is showing access prohibited like a key lock .. Please how can I access the card to open it
这个答案有帮助吗?
Please I need and help . my memory card is showing access prohibited.. Showing lock on screen .. Can't access my or use the card and I have jobs in it . please
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 94
总计 14,838
