跳转到主内容
加入维修社区 - 创建账户
Google 改版 Pixel Buds 的维修信息——这是 2020 年 4 月首次发布的真无线耳机。有时也被称为 Pixel Buds 2 或 Pixel Buds 2020。
Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
由完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Here’s the Ifixit Google Pixel Buds 2 拆解 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
这个答案有帮助吗?
得分 3
1条评论:
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
由完成的
添加一条评论
最有帮助的答案
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Joshua Stouffer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 78
总计 9,778
