Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
这个答案有帮助吗?
Hi,
Here’s the Ifixit Google Pixel Buds 2 Teardown guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 46
过去 30 天: 219
总计 6,446
1条评论
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
由 brandon k 完成的
