跳转到主内容
15 inch "Desk Lamp" iMac G4 700MHz M6498 PowerMac 4,2
Help I accidentally disconnected the Tmds cable
I was working on it and the grounding cable or something got torn off of the board and the frame around it came off halfway.
I could probably solder it but this came off and i need help. not disconnected. it did not damage the board though so it may not be as bad
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Can you post some pics so we can see what you damaged 在已经存在的问题里加入图片
完成的
Yeah I can. Here
完成的
can you please provide pictures so we can have a starting point
完成的
I did. See my edit
完成的
添加一条评论
1个答案
Ouch!
You pulled off the entire connector from the logic board and looking at the image of the logic board you pulled off a few traces as well with the connector.
We might be able to run down a replacement connector but patching the logic board will take some doing. Do you have a friend or know of anyone who has deeper soldering skills as this will take that and working off of a set of schematics and boardview drawings trace back the damaged pad lines to put in the needed patch lines.
While I love the look of this iMac this may end up being a costly endeavor. And given its age may not be the wisest investment.
这个答案有帮助吗?
得分 0
6条评论:
I don’t know anyone who is really good at soldering, but I could get help at an apple store, as I asked and they said that they could as long as they either have parts or don’t need parts
完成的
Well, I've got some bad news for you the Apple Store won't fix your system as the don't have the needed part and at best they would only replace the complete logic board if it was still within the systems they service and in this case the 15" G4 iMac system has long since been removed from their list Obtaining service for your Apple product after an expired warranty you'll find it in the obsolete listing.
To be clear this is basically is a sales gimmick to get you into the store to sell you a new system. So don't be fooled. Thats not to say thats a bad idea its just a matter on what is your needs. Maybe a used system is a better investment like a used 2012/13 iMac or maybe even a Mac Mini if you have a workable monitor already.
Look at an independent Mac repair shop maybe they can help you.
完成的
@danj this is mainly for a collection peice as well as for os 9 to os 10 stuff.
完成的
Yes it’s design was unique! And even today it has something to offer as a show piece.
完成的
@Roman - O, I think I have a way for you to save your system! Here's the needed logic board 15" iMac logic board 700 MHz, Apple 820-1257-A They go for aprox $50 USD used.
That is by far the cheapest way to get your system going!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Roman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 447
