跳转到主内容
加入维修社区 - 创建账户
这是一款索尼唱机,可以通过 USB 连接将黑胶唱片中的音乐转换为 MP3 文件。
Speed adjustment potentiometer stuck?
Hey all, I’m trying to adjust the speed on my PS-LX310BT, which has the same speed adjustment mechanism as the LX300USB, and the speed adjustment potentiometer feels like it’s stuck. I can stick a screwdriver into the speed adjustment hole and hit the potentiometer itself, but either it’s stuck or turning it has no effect. I’m not familiar with potentiometers in anything but guitars, so I don’t know what could be going on here.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Is the turntable rotating? Is the drive belt good?
Just replacing the potentiometer is a possible solution.
完成的
Yep, turntable's rotating and (as far as I know) the belt is OK. Everything's in perfect working order, except for the fact that it plays a bit fast and I can't adjust it because of this potentiometer issue.
完成的
添加一条评论
2个答案
已选择的解决方案
Okay, I finally figured it out. After removing the bottom of the turntable to get to the motor, I found that you need a really small screwdriver to actually get all the way into the hole and turn the potentiometer. I’m not sure what the exact size is, though I think a precision screwdriver that’s a few inches long will fit through the bottom of the turntable. I’ve got it all dialed in now, and it works perfectly! Thanks for the video, Mike.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Are you sure you have the screwdriver in the correct hole? One for 45rpm and one for 33 rpm.
I just spotted this video on speed adjustment for that model:
https://www.youtube.com/watch?v=puq6nghh...
I don’t have a service manual but I suppose it could have a digiPOT:
https://components101.com/articles/how-d...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cr4shMyCar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 59
总计 3,214
