跳转到主内容
加入维修社区 - 创建账户
除了 Tahoe Limited 版本外,该车型在 2000 年款进行了重新设计,采用了全新的 GMT800 平台,该平台仍与全尺寸皮卡和 SUV 共享。
Crank But No Start
I changed the fuel pump, the battery & all my fuses and relays are good but it cranks and won’t start.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论:
Jamani what engine size? Do you have spark on your plugs? Checked the crank and camshaft censors? What else did you check?
由完成的
It’s a 2005 GMC Yukon 2WD 8 Cylinders T 5.3L MFI OHV 323 CID. Im not sure I’ll have to check with my brother he said it started for 10 seconds then shut off again. He changed camshaft sensors I’m not sure about the crank sensor. @oldturkey03
由完成的
I have 2004 Yukon 5.3 same issue more or less I don't have a fuel filter in the tank or on the frame. Still trying to figure out why it won't start
由完成的
添加一条评论
1个答案
Whenever you open a pressurized fuel system you must purge line by turning ignition key to the on position for 10 secs +/- (you should hear pump kick on and stop). Then turn key back to the off position for another 10secs and then try to start. If air is present in line the pump won't pick up fuel. If that's the case crack open fuel line at the filter by turning nut on metal fuel line closest to the engine. The fuel filter is located underneath along frame rail. With the system open, turn on key until fuel has a steady flow then tighten nut while fuel is flowing . Similar to how you would bleed brakes.
这个答案有帮助吗?
得分 0
1条评论:
Ok appreciate it
由完成的
添加一条评论
添加你的答案
Jamani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 58
总计 5,939
