跳转到主内容
8.2 mega pixel point and shoot camera.
9 个问题 查看全部
Why cant I turn on my camera
when i try and turn on my camera i will not be able to push that botton because its stuck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
We are having the same problem. One day the camera was working fine then it just locked up. It seems that the on off button is not responding. We have changed the batteries but it did not help
完成的
添加一条评论
2个答案
已选择的解决方案
Follow this guide up to step 10 and see if the actual button has been dislodged. Once you have gone that far, check the switch without the cover and see if you can "feel " it click. Check for the plastic button in the cover and see if it cracked, broken or if you can loosen it. Hope this helps to get you started
这个答案有帮助吗?
得分 4
添加一条评论
My lens is showing error.My lens is not closing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
smithtamara69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 15
总计 6,929
