跳转到主内容
加入维修社区 - 创建账户
Kodak Easyshare C813 Shutter Button Replacement
你所需要的
  1. Kodak Easyshare C813 Shutter Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
    询问修复机器人
    添加评论
  2. Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 3,3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
    询问修复机器人
    添加评论
  3. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    询问修复机器人
    添加评论
  4. Kodak Easyshare C813 Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
    询问修复机器人
    添加评论
  5. Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 3,3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
    询问修复机器人
    添加评论
  6. Kodak Easyshare C813 Shutter Button Replacement: 步骤 6 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 6 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 6 中的图像 3,3
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
    询问修复机器人
    添加评论
  7. Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 3,3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
    询问修复机器人
    添加评论
  8. Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 3,3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
    询问修复机器人
    添加评论
  9. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 步骤 9 中的图像 1,2 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 步骤 9 中的图像 2,2
    • Open the battery door.
    添加评论
  10. Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 3,3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
    询问修复机器人
    添加评论
  11. Kodak Easyshare C813 Shutter Button Replacement: 步骤 11 中的图像 1,1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
    询问修复机器人
    添加评论
  12. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 步骤 12 中的图像 1,2 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 步骤 12 中的图像 2,2
    • The shutter button is held on to the front cover by three screws
    • Hold the shutter button in place
    • Use a Philips 00 screwdriver to remove the screws.
    • Careful that the power and flash button do not fall off
    询问修复机器人
    添加评论
  13. Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 3,3
    • Keep the shutter button in place while removing the circular metal plate
    • Remove the shutter button by allowing it to fall into your hand
    询问修复机器人
    添加评论
  14. Kodak Easyshare C813 Shutter Button Replacement: 步骤 14 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 14 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 14 中的图像 3,3
    • Hold down the shutter button portion of the selector dial
    • Press down the red tabs and slowly relieve pressure on the shutter button
    • Press down on the center red stick
    • Careful not to lose the spring
    • Tool shown is Found here
    询问修复机器人
    添加评论
  15. Kodak Easyshare C813 Shutter Button Replacement: 步骤 15 中的图像 1,1
    • If cleaning, remove dirt from button
    • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G22
4 名成员
创作了22篇指南
1指南评论
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 42
总计 8,496
