跳转到主内容
加入维修社区 - 创建账户
Melitta 的小型全自动咖啡机。这些指南也适用于其他 Melitta 机型,以及 Nivona、Siemens 和 Miele 的全自动咖啡机——它们的结构非常相似。
Power fuse. Where is it?
I’m trying to find the Power fuse im our Cafeo Solo.
Where is it placed? And what type of fuse is it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@VauWeh any idea about this? @jannegus ,he is the coffee machine guru and wrote the guides for this model. The @ should notify him of your question. Let's see what happens
由完成的
添加一条评论
1个答案
最有帮助的答案
All heating appliances must have thermal fuses to prevent a fire. They’re in line with the power inside the case clipped to the heating element section.
One version looks like a 3/16” diameter x 1/2” cylinder with an epoxy tapered plug in one end. One wire is attached at each end.
Another common version is a 1/2” diameter x 3/8” high can with 2 mounting tabs and 2 spade lugs for the wires.
I hope it has the rating marked, usually in Centigrade, otherwise you’ll have to find it. Thermal fuses are made in a wide variety of temperature ratings - it’s dangerous to guess it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jan Gustafsson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 29
总计 660
