跳转到主内容
加入维修社区 - 创建账户
Kenwood Eleven III 型 FM 立体声接收机。这款立体声设备来自 20 世纪 70 年代。
Dimmer switch not working?
How to fix dimmer switch on Kenwood model eleven III
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
fogdog57 what happens when you try and use it. Does not work at all? Intermittent? Any change when you wiggle it? It does have a display (you know the bulbs are good)? You have more identifier on the receiver. Is it a KR-10000/7600/9400/9600/9050 etc.?
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi
Here’s a composite image taken from the service manual showing the dimmer switch circuit.
Looking at the circuit the switch at normal bypasses the 1Ω 7W resistor in the power supply path to the lamps (see red arrow line) and when operated inserts the resistor into the circuit (see green dotted line).
(click on image to enlarge)
Unfortunately the parts list doesn’t have the switch part number only the board number (X13-2190-10) where the switch is located.
If the switch is faulty and not say the resistor etc then search for a suitable DPDT switch (double pole, double throw). The voltage supply for the lamps is only 7.5V DC and the power rating for the resistor (7W) indicates that the current is about 1A. Search for a switch that has these specifications as a minimum e.g. 2A DPDT locking switch.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
fogdog57 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 327
