跳转到主内容
型号 A1019 / 10 或 20 GB 硬盘 / Firewire 接口为普通大小
29 个问题 查看全部
iPod 2nd generation Headphone jack broken
Hi - my headphone jack is broken. I took the iPod apart and the headphone jack is soldered to board. Any idea how to replace it? I found a replacement part online but dont know how to use it. My model number is M8740LL/A. Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have the same problem, please pass on the details of the replacement headphone jack so I can order one myself- thanks!
完成的
Can you please post what the replacement part is? I've looked everywhere!
完成的
添加一条评论
1个答案
已选择的解决方案
You can try and solder it yourself after you practice on some other components until you become proficient, or you could just take it to your local TV/Radio repair person and have them solder it. Remember that what makes these guys usually expensive is to dismantle and diagnose, which is time consuming. In your case, it's disassembled and should be straight forward. Also, do not forget your local High School and Colleges, check for their electronics courses, if you do not a TV repair person handy. They are almost as hard to find as parts for your iPod. ;-) Electronics Skills Kit 101 and http://www.aaroncake.net/electronics/sol... might be a good start....good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nbhidemisc 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 6
总计 686
