跳转到主内容
Manufactured from 2004 to 2009, the Vino 125 has a 125cc engine.
22 个问题 查看全部
Engine is making a bubbling gurgling sound like a percolator.
Bubbling gurgling sound in engine after it warms up. Drained and flushed radiator and oil. Both normal no discoloration. Engine also cracks back at full throttle. Any suggestions or thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sounds like the radiator is not holding pressure. Try replacing the radiator cap first.
这个答案有帮助吗?
得分 0
1条评论:
It's holding good and snug, never had any problems with it. Doesn't leak or anything like that.
完成的
添加一条评论
Richard Mallette “Engine also cracks back” could be a timing issue as well as a fuel delivery issue. The “Bubbling gurgling sound “ could be caused by air in the coolant system. You did not tell us if this all just started or if this has been going on for a while.
这个答案有帮助吗?
得分 0
4条评论:
Just started yesterday
完成的
And is 49cc single cylinder
完成的
The coolant was kind of low when I dumped it and replaced it, but how do I purge it if air did get into the system?
完成的
Richard Mallette what is the exact model number for your scooter
完成的
添加一条评论
添加你的答案
Richard Mallette 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 82
