跳转到主内容
加入维修社区 - 创建账户
2008 年推出的上网本;型号 ZG5 AOA150-1691;8.5 英寸屏幕;1.6 GHz N270 英特尔凌动处理器
changing OS to windows 7
since this netbook performs badly on windows xp is it a good idea to change OS to windows 7?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
2条评论
Best to upgrade hard drive to SSD:
Acer Aspire One ZG5 硬盘更换
由完成的 分享
It is very simple and free to upgrade to Windows 10 from an earlier activated copy of Windows. Just download Windows 10 Upgrade from:
https://www.microsoft.com/en-us/software...
Run it from within your current legal copy of Windows - remeber to select keep files and apps and away you go. Not difficult at all. It helps speed things up if you upgrade all your current drivers before running the Upgrade app. DriveBooster from IOBit is a good driver updater. Freeware version is fine.
由完成的 分享
添加一条评论
11个答案
已选择的解决方案
E Carson gives good advice--you need to know your computer will run 7 before you purchase it. That said Win 7 is a much better OS than XP and I would definitely upgrade. I would recommend the OEM package for $99 unless you are planning to sell the netbook soon. (The retail version is $200) Windows 8 is scheduled for release late next year (maybe) and if replacing the computer after that you probably would want the newer system. + for Carson.
这个答案有帮助吗?
得分 5
添加一条评论
The most correct answer would be to download Microsoft's Upgrade Advisor. This program will evaluate your system and software and offer options to the same.
Get it here:
Microsoft Upgrade Advisor
这个答案有帮助吗?
得分 4
添加一条评论
Windows 7 system requirements are somewhat higher than windows XP
I have tried Windows 7 on one of these and it runs waaay too slow my suggested alternative to Windows XP is Ubuntu Linux its free it works with this machine pretty much out of the box! (www.ubuntu.com)
这个答案有帮助吗?
得分 2
添加一条评论
Windows 7 Starter works well on the ZG5. The Starter version is designed for Atom processors. I am typing this on the ZG5-W7 Stater now. CPU usage jumps to 90 - 95% during page loads but quickly drops. 1gb ram installed and seems to hover around 47% with 4 tabs open on Chrome.
这个答案有帮助吗?
得分 2
添加一条评论
Acer Aspire One 532
Works fine with Windows 7 Professional 64bit
and an SSD.
这个答案有帮助吗?
得分 2
1条评论:
Actually works with Windows 10 Pro 64-bit version 1803 build 17134.112 as well
由完成的 分享
添加一条评论
windows xp service and support will not offer anymore from micorsoft. if you use windows xp you may have security issues so i would sugest you to update OS to win 7. if you expect proformance of the laptop you can update the RAM up to 3GB. :-) 2GB is engouh as you run 32bit os
这个答案有帮助吗?
得分 2
2条评论:
Acer Aspire One ZG5 can only upgrade to 1.5 RAM. When support for WinXP was discontinued, I removed it and installed Ubuntu 14.04 32 bit. I still use this little laptop to this day. I added an extended battery, new keyboard and upgraded to 1.5 RAM and it works pretty good. Slower than tablets and smartphones are today, but this is still a favorite of mine. There is just something unique about this tiny laptop that keeps me using it. If anyone else has this same Acer Aspire One ZG5 netbook, I would suggest the same additions that I have done. I plan on using this computer until it absolutely dies. Half of the fun is tinkering to see what I can get it to do. It lags while streaming video from Youtube, but mostly from the ads, I use it to watch Netflix still to this day(thanks to Chrome). Don't know why, but I love this laptop.
由完成的 分享
Recently installed Lubuntu 16.04.1, pushing (beloved) XP to the side. My little Acer ZG5 runs as if it just came out of the box! (minus the "Y" key)
I may have found a new love in Lubuntu.
由完成的 分享
添加一条评论
I was able to install a Windows 10 (test install) and it worked very well with the touch pad and all functionalities of the AcerOne.
Only issue is that I can not install the Windows 10 licensed version after the test install expired.
I'll persevere and let you know how well Windows 10 install/works.
这个答案有帮助吗?
得分 2
1条评论:
I reverted back to Windows 7, SP1 and then downloaded an upgrade to Windows 10. The upgrade was successful and now I'm running Windows 10, winver shows the version as 1511 OS build 10586-679, a licensed version of Win 10 having installed Win7, SP1 licensed version.
Now, I'm working on having a Win10 IoT core installed on a Raspberry Pi 3 and get these two working together. That will be fun !
由完成的 分享
添加一条评论
One of the things I find interesting is the anti-windows/gates nonsense. You need to build a system that suits YOUR needs and budget, not the political whims of others. As a professional writer with several systems I use Windows, Ubunto & Mac OS. As XP goes away soon, I will move my older netbooks to Ubuntu exclusively. However, I am still faced with the need to use Microsoft software, which I can do on an upgraded desktop and my old Mac. But for portable use, I eventually will have to get a Windows machine so I can run Word. I use Both Word and LibreOffice Writer, but the latter is good mostly for draft work. If heavy editing is required, along with other formatting, Word is better than LibreOffice Writer. At least I can meet 80% of my needs with LibreOffice, but the other 20% requires the MS product. For photowork, GIMP does a pretty good job vs Photoshop - but I am not a high end photo guy - those folks need Photoshop. For layout, nothing beats Adobe InDesign (the open source alternates are crap), so you have to gag on the price. Fortunately, I can do all that I need with older versions. So--I can write a novel in LibreOffice/Ubuntu but I cannot efficiently design a book interior for upload to CreateSpace with it. There are many other limitations as well. In short, I recognize and honor the budgetary implications of going open source - but that should be the consideration - not the political BS.
这个答案有帮助吗?
得分 1
添加一条评论
I am using the Acer Aspire One ZG5, and this is 2015. Something special about this little computer. My advice is to run Ubuntu 14.04 32 bit. Not many of these netbooks still around, since they are being replaced by the tablet market. But if anyone still has one, they are still usable. Check my response earlier in this post for ideas.
这个答案有帮助吗?
得分 1
2条评论:
Mine is still ticking over nicely. I've unmasked the Advanced options within the BIOS which allowed me to enable AHCI mode which in turn gave me the option to install an SSD. Now running Windows 7 Professional 32 bit on 1.5GB of RAM. Now the thing works as it should.
由完成的 分享
ok mais j'ai un Acer Aspire One ZG5 qui faire 8GB
由完成的 分享
添加一条评论
igraph65, I must say that I appreciate you suggesting Ubuntu. I myself am a Linux user, currently running modified Kali Linux but I started with Ubuntu as my first Linux Disto. For a 32 bit installation of Windows 7 your computer needs 1gb ram while a 64 bit installation requires 2gb ram. I'm sure that one could get Windows 7 to install on a system with specs not quite matching the recomendations but things might not go well. That being said, anyone out there that's feeling adventurous and would love to try a free and MUCH MUCH better OS than Windows, look into either Linux Mint or Ubuntu (note that Linux comes in a variety of desktop flavors so be sure to look into that before installing the first one you find. Ubuntu for example has Lubuntu, Kubuntu, Xubunu. Each of which portrays your desktop environment in different ways) IN A WORLD WITH NO WALLS, WHO NEEDS GATES AND WINDOWS?
这个答案有帮助吗?
得分 0
添加一条评论
I have got a Acer Aspire one zg5 which had xp os before. Now it is installed windows 7 starter service 1. Got 1 gb ram with 32 bit. I am feeling that nowadays it is lagging. So, what is the good solution for my netbook? Can anyone suggest me what is the best way for my netbook? Thank you.
这个答案有帮助吗?
得分 0
3条评论:
Show your Acer some love.... install Lubuntu 16.04.
由完成的 分享
The Atom CPU is the bottle neck here I have another Acer netbook where I changed to SSD Windows 10 and 2GB of ram better that before but it still takes some time to start programes like word or Firefox. but otherwise usable.
由完成的 分享
I agree with Claes.
由完成的 分享
添加一条评论
添加你的答案
lemuel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 44
总计 39,321
