跳转到主内容
Lenovo's ThinkPad T530 is a durable, repairable 15.6" laptop released in 2012.
How can fix Black spots in the screen
Update (09/10/2021)
black spot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
what did you do to it before it got black spots
完成的
Hi @adly83 ,
Post an image of the problem so it can be seen.
Here's how to do this on Ifixit 在已经存在的问题里加入图片.
Have you tried connecting the laptop to an external monitor and check if the problem is on it or if it is OK?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi,
The LCD panel is faulty and needs to be replaced as it cannot be repaired.
Here’s the hardware maintenance manual for the laptop.
Go to the bottom of p.106 to view the necessary pre-requisite steps and then the procedure to remove/replace the LCD panel.
Replacement panels are available online. Just search for Lenovo T530 LCD screen to find suppliers that suit you best.
Usually the Lenovo part number can be found on the back of the panel itself, if you wish to confirm that you’re ordering the correct one, as there are several different panels available for the model series. If there is one there, then search for the LCD panel part number instead of the laptop model number, to be sure that you’re getting the correct one. Alternatively contact the seller and verify that it is compatible with your exact model.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mohamed Adly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 374
