跳转到主内容
Third generation of the Fitbit Charge fitness tracker series.
My fitbit charge 3 is different?
As you can see in the image my fitbit charge 3 has three ribbon cables coming from the screen where the one of the teardown has only 2. My replacement screen also only has two. Can anyone explain this? What kind of connector is this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Are you sure this is an authentic fitbit? it could be a knockoff that for what ever reason needed another cable
这个答案有帮助吗?
得分 1
1条评论:
I am 99% sure. I also just found the box and it states that this is a special edition with fitbit pay. Maybe that the pay mechanism needed the extra cable, and it makes sence that this is mounted under the glass since the signal doesn't transfer through metal. Also the replacement screen works even without the extra cable!
完成的
添加一条评论
You have a special edition Charge 3. You see them on occasion. If you have the sticker on the back of the screen, that should be removable and then you can apply it to the back of a replacement screen. Otherwise, ignore it and the payment option will just stop working. It's not a big deal if it does so unless you have a use for it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Niels Fennema 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 375
