跳转到主内容
加入维修社区 - 创建账户
Rakuten Kobo 制造的电子书的维修指南和故障排除。
Kobo - Replacement button
I’m trying to find a replacement button for my Kobo Ereader, the rubber went brittle and crumpled :(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What model is your Kobo e-reader?
完成的
It's a 2010 Kobo WiFi
完成的
添加一条评论
3个答案
已选择的解决方案
Most of them have very generic buttons found in many devices, but usually requires soldering to replace them. Heat station and an iron would be requite usually.
If it’s the type of button I’m thinking about you may find some on digikey or amazon sometimes.
Can you send a picture of the button?
I hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Did you find a solution? I have a white Kobo 2009 (no wifi). The rubberized square button on the front has deteriorated and crumpled too.
https://kolico.ca/tmp/kobo1-IMG_20210916...
A closer look:
https://kolico.ca/tmp/kobo2-IMG_20210916...
:( This is a sad time for me.
Can anyone think of a suitable hack?
这个答案有帮助吗?
得分 0
3条评论:
I have the same problem, would love to hear a solution
完成的
Can we not get a replacement button or do we thrash the economy reader?
完成的
If it's the external button in the case, you might have some success making a replacement out of hot glue and / or a stiff bit of plastic - that what I'm trying
完成的
添加一条评论
Why does this say solved when it clearly isnt?
Same issue, same side of the button even.
I did find this, though it's not a soft button, but it's certainly an option? Haven't tried it yet though, need to talk to a friend with a printer.
https://www.reddit.com/r/functionalprint...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Caitlyn Patterson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 123
总计 5,614
