跳转到主内容
加入维修社区 - 创建账户
Nissan Rogue 是一款由日本汽车制造商尼产(Nissan)生产的紧凑型跨界 SUV(运动型多用途车)。Rogue 于 2007 年首次发布,作为 2008 款车型销售。
Steering controls not working.
My nissan just started doing this. The cruise control as well as all the options on my steering wheel just stopped working a couple days ago. This morning my horn will only work if I am almost or fully stopped and the air bag light just started flashing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Did you try searching for Nissan forums then sub groups for Rogue members? Many use online forums to share problems, maintenance, ideas, mods, etc, with other owners having the same model. Free online help is second to none compared to paying for dealer ore repair shop services.
Did you check the easy things like blown fuses in the engine bay or inside the cabin?
这个答案有帮助吗?
得分 0
2条评论:
I have not checked the forums. I will check them out. I am hoping it is as easy as a fuze. I was trying to figure out where to start looking before taking it to a shop. Thank you for giving me some directions to look.
由完成的
its usually a clock spring/spiral cable issue which can be as simple as the connection/harness coming loose needing to be "plugged" back in (reconnected) or it could be a single wire in different bundles of wires broke. You can find replacements pretty easily ive even seen them at walmart for like $30 http://bit.ly/3DLNP6B
Note you have to be comfortable taking the steering wheel column apart and be extremely careful/mindful that you disconnect the airbag first thing and do not short it … then set it down with the outward face (the side you see when driving) face up away from where you are working and out of the sun. In case it were to go off that limits the shrapnel that it could send flying… remember it is nissan we are dealing with here. Youtube can show any handy person how to do it.. its a 30 minute job max. you need a security star bit or you can make one using a drill (or possibly even printing one with the right filament) but harbor freight gets you a set for like 10 bucks.
由完成的
添加一条评论
its usually a clock spring/spiral cable issue which can be as simple as the connection/harness coming loose needing to be "plugged" back in (reconnected) or it could be a single wire in different bundles of wires broke. You can find replacements pretty easily ive even seen them at walmart for like $30 For Nissan Rogue 2008-2015 2.5L l4 New Clock Spring Spiral Cable B5567-JM00B USA <<part sold thru walmart. I promise its a safe link but run it through virus total yourself .. i wont be upset.. thats good practice you should do for any link.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Bickers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 68
总计 2,600
