跳转到主内容
加入维修社区 - 创建账户
用于 Dualsense PS5 控制器的充电底座。
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
did you ever find a way?
完成的
添加一条评论
3个答案
最有帮助的答案
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
这个答案有帮助吗?
得分 2
添加一条评论
See my teardown over at Dualsense Charging Station Tear Down Guide
这个答案有帮助吗?
得分 2
添加一条评论
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sulakshan Rajaratnam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 64
总计 2,087
