Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
这个答案有帮助吗?
Thanks for all your help!
I am sorry, I missed to add another pad, the one right next to the purple one.
no problem, pict upgraded
hi can i you help me to pin point positive and negative pin to charge the ipad 6th gen beacuse the pin was destroy im trying put jumper on it
Hi @bryanlutuaco ,
yes, of course. unfortunately, it is difficult to post anything in the comments section :-) So start a new thread and throw a link (preferably by email - you will find it in the "about me" tab) so as not to miss it in the thicket of other messages.
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 85
总计 1,845
5条评论
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
由 bert.harmidomski 完成的 分享
I am missing the ones highlighted in light blue.
由 mmejia04 完成的 分享
wait...
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
由 oldturkey03 完成的 分享
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
由 mmejia04 完成的 分享
