跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
iPhone 11 Pro Max apple logo loop.
The back of my iPhone broke badly and it began to do the apple logo loop so then I restore it and it came back on but again it started doing the apple logo loop. Would the problem be that the back glass broke and maybe it broke the wireless charging pad? Or what could be the problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
There are multiple issues that can cause this. I would suspect a faulty part. Since you have Brocken the back glass I would recommend sourcing another housing for your logic board. If you wish to keep that housing the parts that can be causing your issues are:
·         Battery.
·         Charge port.
·         Screen.
·         Front flex assembly.
·         Front or rear camera.
In some rare instances a hard drop can also cause the NAND or CPU to be compromised which would end up in a costly repair.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem with my 11 after replacing the back and the battery it seemed to boot fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steve Carrasco 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 17
总计 500
